My turn signal relocation
Old Jan 9, 2010 | 02:40 PM
twisted125's Avatar
twisted125
Cool My turn signal relocation
Following Story's words, I relocated my turn signals to below my forward controls. Having been asked about how I did it last night, this is to show where I mounted them and how.
I used the holes under my forward controls. I cut the 3 wires staggering about 1" away from each other, beginning my cuts about 3" away from the turn signal housing. After cutting the lights off, I pulled the remainder of the long wire through the trees where they were originally routed and down toward the forward controls. The wires met back together perfectly. There is about an inch or so of "slack" but considering I was prepared to lengthen them, I was pumped about them meeting up the way they did. I used some butt crimp connectors with built in heat shrink, then covered the 3 connectors with about an 8" section of heat shrink. At the base, I just picked up some 5/16" - 24 - 3/4" bolts, some washers, and lock washers. Putting the bolt through from the inside, one washer on the head side of the bolt, then through the bracket, a washer, lock washer, and another washer, lock tite, then started the threads into the housing.
Old Jan 9, 2010 | 02:47 PM
Ez69's Avatar
Ez69
Awesome location, I would think seriously about mounting some small spots there myself. Need some pics of it at night.
Old Jan 9, 2010 | 02:49 PM
aviator's Avatar
aviator
I just installed a set of running lights in the same place - no photos yet.
Old Jan 9, 2010 | 05:07 PM
DrawDown's Avatar
DrawDown
Thats pretty tight, Some small bullets would be even better. Good mod bro.
Old Jan 9, 2010 | 05:40 PM
Rockyriver's Avatar
Rockyriver
Thats a cool idea. I love it on your bike.
Old Jan 9, 2010 | 09:20 PM
story808's Avatar
story808
Looks real good Twist... Hows the bars coming along?
Old Jan 10, 2010 | 08:44 AM
m i k e's Avatar
m i k e
looks like there are pointing down is that just pic?
nice mod great spot for sigs
Old Jan 10, 2010 | 08:59 AM
WARG's Avatar
WARG
Very nice mod. I would consider that if I had not already moved mine to my forks.
Old Jan 10, 2010 | 09:44 AM
tk353's Avatar
tk353
what about speed bumps and twisties? wont they hit
Old Jan 10, 2010 | 09:45 AM
tmitchellof PG's Avatar
tmitchellof PG
I'd like to see some photos of your running lights in place.
Tom
