96ci "B" Balanced Engine?
Old Jan 13, 2010 | 09:05 PM
kentuckydave's Avatar
kentuckydave
Northside knows what he is talking about. You can take that to the bank! The Dyna does not have the "B" motor and should be smoother at cruising speed than the "B".
I have a 96B and it is a vibrating POS at higher RPM. I almost traded it off with only 5K miles on it. I did change the grips out to the soft, sponge rubber, cruiser style grips. That helped quite a bit.
I also changed the angle of the bars and it helped me relax a little. I am not not holding the grips near as tight as before. It moved the grips back further and it helped.
I also put a throttle boss on the right grip so that I don't have to hold the grip tight in order to accelerate or cruise down the road. Even with the throttle boss I get a cramp in the right hand once in awhile.
Old Jan 13, 2010 | 11:48 PM
micahpop's Avatar
micahpop
I don't know what year or model you have but it must suck to have to ride around all the time at low rpm's.
Glad mine's not a vibrating piece of ****... (which would soon turn to tiny little pieces of **** )
Old Jan 13, 2010 | 11:55 PM
toastman's Avatar
toastman
sounds like some quality bushings for the risers and a vibration dampening system for his bars will take care of his troubles.
i think mud installed "vibranators" in his bars...check for his post in the dyna section.
Old Jan 14, 2010 | 08:12 AM
tk353's Avatar
tk353
i had that hand issue and ISO grips solved it. it is the first mod when i got my new bike
Old Jan 14, 2010 | 11:01 PM
oct1949's Avatar
oct1949
Originally Posted by FastHoss
Something doesn't sound right here.That is the same engine in both.Only the touring models are rubber mounted and very smooth.The "counter balanced"engines are in the other models ,except the Sporster and V Rod.
Originally Posted by beaureed445
Not totally correct....Tourning and Dyna models are both "A" motors. Softails are the only "B" motors.
Fast hoss better listen to beaureed445 cause he's right... dynas are rubber mounted also..
Old Jan 14, 2010 | 11:11 PM
oct1949's Avatar
oct1949
Three yrs and almost 25k and I don't notice any vibrating at higher rpm's.. don't ride over 75 and usually 50-65mph, don't even notice a buzz that some others say... maybe the bars on the heritage, I don't know.
Old Jan 14, 2010 | 11:42 PM
magnum629c's Avatar
magnum629c
go 85 to 90 you will feel it.
Old Jan 14, 2010 | 11:48 PM
klaybus's Avatar
klaybus
GRIPS!
Replaced the skinny grips that came on my Heritage to some aftermarket larger diameter HD grips & the problem was gone! $75 for new grips is a heck of alot cheaper than an engine or trading in your bike.....
Old Jan 15, 2010 | 04:00 AM
Keithhu's Avatar
Keithhu
Originally Posted by klaybus
GRIPS!
I don't have any vibration problems with my Heritage, but I'm having difficulty imagining vibration problems that are that bad that would be that much improved by grips, but glad yer squared away. I have the HD Stealth grips that will be going on the bike in the spring, but I guess now it will be outrageously smooth, vs just fine.
Old Jan 15, 2010 | 05:09 PM
klaybus's Avatar
klaybus
Actually I didn't have a "vibration issue" at all. I did however experience the numbing issues many on here report about. I suspect part of my problem was holding the grips too tight. When I learned to hold on less tight, that helped with the numbing issues but when I went to larger diameter grips....The issue was resolved for me. I too have read that the rubber mounted engines on the dyna models shake like hell at a stop light but as soon as you take of the vibration disappears. I haven't experienced ANY vibrations issues on my Heritage at all......
Clay
