Bank angle sensor...location?
Old Jan 17, 2010 | 07:56 PM
MGN54's Avatar
MGN54
Default Bank angle sensor...location?
Hi,
Owner of a Night Train I looked at is trying to trace down a cutting out problem and wants to check the BAS. Where is this located on the train? Picture might be good as well.
Also, there is a black plastic looking box directly under the seat. Has two harnesses coming out of it. It is cracked and he has wrapped it with electrical tape to keep out moisture. What is this box? Main circuit breaker possibly?
If he can nail this problem down, I would be interested in the bike possibly.
Thanks!
Old Jan 17, 2010 | 07:57 PM
MGN54's Avatar
MGN54
Forgot...this is on a 2000 carbed NT.
Old Jan 17, 2010 | 10:16 PM
DaveFLSTFB's Avatar
DaveFLSTFB
Not sure if this will help but i had a late model carb'd sporty at one time and had the same issue. After a while of searching (and almost getting run over a couple times on the highway) I narrowed it down to a loose ground. My negative battery terminal would not stay tight, and the ignition module would cut out because of it. Replaced the battery and never looked back.
Dave
rquest
Nov 5, 2016 11:23 AM
soldier of fortune
Electrical/Lighting/Alarm
May 18, 2012 06:51 AM
soldier of fortune
EVO
May 15, 2012 03:30 PM
nighttrain576
Exhaust System Topics
Mar 31, 2010 01:54 PM
jfgiunta
Oct 12, 2009 11:26 PM
