Removing the plastic fender protector
Old Jan 21, 2010 | 08:43 AM
DaveFLSTFB's Avatar
DaveFLSTFB
I like that idea
Dave
Originally Posted by tk353
i removed mine and stuck it on the bottom of the stock pinion seat
Old Jan 21, 2010 | 12:43 PM
Hammy's Avatar
Hammy
tape sounds like a good idea, the felt ot carpet will wear the paint right off, dust and dirt gets into the carpet/felt and with the vibration wears the paint right off.. the rubber pads seem to work best, seems like the tape would work too..
Old Jan 21, 2010 | 07:45 PM
Dorkman's Avatar
Dorkman
Originally Posted by oct1949
I would say without protection on the fender of some kind its going to at least fuzzy dull the paint where the 2up seat hits the fender even with felt, but shouldn't scratch it
Ditto that. The felt, carpet, or whatever will rub the paint with the movement of the seat and fender. The more dirt that gets in between, the worse it gets. A temporary solution is wide clear packaging tape or wide black electrical tape on the fender. Just remove the tape when you remove the passenger seat.
Old Jan 21, 2010 | 08:33 PM
tk353's Avatar
tk353
Originally Posted by dorkman
ditto that. The felt, carpet, or whatever will rub the paint with the movement of the seat and fender. The more dirt that gets in between, the worse it gets. A temporary solution is wide clear packaging tape or wide black electrical tape on the fender. Just remove the tape when you remove the passenger seat.
best ideal
Old Jan 21, 2010 | 08:39 PM
Nickrc3's Avatar
Nickrc3
Has anybody removed the paint protector on their fender to run a 1up seat, and then switch back to 2up on occasion. I was curious if their paint got marked up after the 2up seat was on?
Iused
Nickrc3's Avatar
Nickrc3
Iused a
Old Jan 21, 2010 | 08:48 PM
Nickrc3's Avatar
Nickrc3
Accidently hit the 'post' button -
I replaced the origianl plastic protector with a film called 'Frisket' paper which is used for custom painting and available in most craft stores. It stretches nicely on a curved fender and has a low tack adhesive, so removing it is never an issue. It also offers good protection upon placement of the 2up seat. Probably contact shelf paper would also work.
I now only use the solo seat w/ bib pictured.
heiner921
Dec 8, 2018 08:47 AM
keikanca
Feb 17, 2012 06:39 AM
08fxstb
Apr 13, 2008 04:33 PM
tinger82
Aug 11, 2007 05:44 AM
RandyM1911
Oct 5, 2006 01:13 AM
