Deuce tank fitment question
Old Jan 20, 2010 | 02:55 PM
bensonjv's Avatar
bensonjv
Default Deuce tank fitment question
Starting a winter project a bit late.
Will a 2006 or older Deuce EFI tank fit on a 2007 EFI Deuce?
Since HD is known to tweak stuff from year to year I wanted to know if anyone was aware of compatibility issues.
Thanks.
Old Jan 20, 2010 | 05:02 PM
Dieselhed's Avatar
Dieselhed
Yes, they are the same tank. I know on the '07 there is now a bracket to mount the fuel gauge sender inside the tank. Can't remember if they started that in '06 or not. I have an '02 that I just put an '07 tank on.
Old Jan 20, 2010 | 05:05 PM
AzDeuce's Avatar
AzDeuce
I have been considering a paint set............from what I have found is that all Deuce EFI tanks are interchangable....they have a plate welded in the tank for EFI models.
Old Jan 20, 2010 | 05:49 PM
SpicOfTheDevil's Avatar
SpicOfTheDevil
yes it will...the '06 efi deuce tank has the bracket for fuel gauge float...the '05 efi does not, but it's not hard to make one...question the tank seller about the float bracket if you want to avoid making one
the '05 efi has the float screwed to the plastic that holds the fuel pump, there's no bracket for it...the float is different
Juiced_deuce
Jan 1, 2014 10:48 PM
bensonjv
Feb 20, 2011 08:18 PM
flexx220022
Mar 11, 2008 07:37 PM
flexx220022
Jun 23, 2007 12:13 PM
SteveP
Jan 9, 2006 12:14 PM
