06 FXST Lowering 2" Rake front too?
Old Jan 20, 2010 | 11:40 AM
BgEarl's Avatar
BgEarl
Stage III
Default 06 FXST Lowering 2" Rake front too?
Im looking at lowering my FXSTI about 2 inches. Its a second bike for me, I ride distance but not on this bike. I know I need to do something to the front if I lower the back, so I'm thinking of a raked tipple tree, not alot, maybe 3deg or so?
Any thoughts on how much rake I would need? I don't want to modify the frame because, well it just scares me.
Big Earl
"live every day like your last and every night like your first"
Old Jan 20, 2010 | 12:28 PM
mike06train's Avatar
mike06train
I wouldn't rake it but you could install lowering springs in the front forks. That would keep the geometry close to stock and the steering neutral.
Old Jan 20, 2010 | 01:10 PM
Northside's Avatar
Northside
Big Earl
Raked trees on a stock frame scare me worse! They reduce "trail" which is fine on a radically raked frame, because they have too much trail. The stock bikes geometry provides around 4" of trail. Reducing it very much causes a very unstable bike. Your bike doesn't push the front wheel, it pulls it. Trail is the distance the axle is behind the plane of the fork stem and neck. If you extend a line through the neck to the ground it will be ahead of a vertical line through the axle to the ground. That distance is your trail. Increasing the angle of the fork with out increasing the angle of the neck reduces trail. A good example of negative trail is a shopping cart with the caster turned forward. If the axle is ahead of the pivot (same as your fork stem) it will flop then turn 180 degrees until it is behind the pivot (trailing). The cart pulls the wheel fine it does't push it well. Your bike won't either. This was a lesson learned the hard way by guys taking short cuts back in the seventies. I know I was building chops back then.
Old Jan 20, 2010 | 07:17 PM
djcustom1's Avatar
djcustom1
I know there is a lot of pros and cons to racked trees, but if you to the right people you can safely go to 7 degree and lose vary little in the ride. Dont take the first thing you hear as being the one ,it takes home work and knoledged people. Most harleys come with 32 degree rake. I have been talking to people at mean street products and thay are vary good.
Bagger Jim
Feb 17, 2012 07:32 AM
hogster1961
Jun 7, 2009 09:10 AM
mtnlvr
Jan 10, 2009 12:49 PM
69sport
Aug 1, 2006 01:21 PM
kaduku
Jun 18, 2006 05:31 PM
