Dash Panel Question
Old Jan 31, 2010 | 05:25 PM
pascoz28's Avatar
pascoz28
Default Dash Panel Question
Hello! I've tried searching for over 4 hours on this and other forums and the internet in general and can't find an answer to this question:
Does the dash panel for a 2000 Softail (HD Part#71273-00) fit properly on a 2000 Wide Glide (HD Part#71246-99)?
I know the easy answer is 'no' because they're different part numbers...but I've found that there are usually several part numbers that will fit in multiple applications. I just can't find information on this particular interchange. There are very few WG-specific dashes out there...LOTS of Softail ones. They are seemingly identical...but there's gotta be a difference.
Any insight would be appreciated! Thanks.
Old Jan 31, 2010 | 06:00 PM
DR.Greenthumb's Avatar
DR.Greenthumb
You might check an aftermarket catalog and see if any of their custom dashes are interchangable between those two tanks,if so I'd think the HD dashes are too.
Old Jan 31, 2010 | 06:17 PM
pascoz28's Avatar
pascoz28
Thanks for the idea. I've checked V-Twin and Dennis Kirk. There's gotta be some sort of difference because they do list the Softail and WG dashes as being different. It must be VERY slight because they look identical in every pic I've seen.
Does anyone out there know what the difference is? I thought a 2000 Softail and a 2000 WG had the same tank...
Old Feb 1, 2010 | 10:12 AM
tk353's Avatar
tk353
what panel did you need?
Old Feb 1, 2010 | 08:24 PM
pascoz28's Avatar
pascoz28
I found out that the tanks are, in fact, different in where the mounting tabs are. If the curvature of the tanks are the same, the Softail console MIGHT fit. I'm purchasing a used Softail console to see what exactly the difference is. I'll post up when I figure it out.
Old Feb 2, 2010 | 12:35 PM
wiseguy2day's Avatar
wiseguy2day
Wouldn't everything depend on the fatbob tank? If your wideglide has the fb tank then the softail console should mount up.
wedgehead
Sep 12, 2012 07:13 PM
pascoz28
May 9, 2010 12:47 AM
pascowg
Jul 19, 2007 07:25 PM
clearsky2007
Motorcycles For Sale
Jun 21, 2007 07:42 PM
sundancewind
Apr 30, 2007 11:25 PM
