Hard Clunk when put in gear ??
Old Feb 7, 2010 | 10:40 PM
ScReaMnEagLE22's Avatar
ScReaMnEagLE22
Default Hard Clunk when put in gear ??
What can be some of the things that would cause a hard engaging transmission ? Seems like when I put the bike in gear it seems to go in harder than normal.
Im currently running the SE Synthetic oil.
Old Feb 7, 2010 | 10:48 PM
Rockyriver's Avatar
Rockyriver
If the clutch is adjusted correctly, try a better Primary oil. And i don't mean the Harley Brand oils. I use Drag Specilties Big twin Primary (Me and my friends love it). But I hear a lot of good things on the Redline oils also. This is of course the cheapest and easiest thing to try to change. I tried the Syn 3 20/50 in my Primary and the clutch did'nt seem to desengage as good as when I had a no name cheap Primary oil in it. Just my .02 cents worth.
Old Feb 7, 2010 | 11:09 PM
BLKBAGGER's Avatar
BLKBAGGER
That's one reason I run ATF in my primary. The clutch seems to disengage better with it. I would try what the above post says and try an adjustment and a different fluid.
Old Feb 7, 2010 | 11:11 PM
PistonPuller's Avatar
PistonPuller
Try adjusting your clutch and clutch cable, its real easy to do. See if that helps.
Old Feb 7, 2010 | 11:12 PM
Other Sheep's Avatar
Other Sheep
Also might try gear oil in the tranny. Harley doesn't recomend the syn 3 in all three holes anymore. Also, when the bike is cold, work the clutch lever a few times before dropping it into gear.
ScReaMnEagLE22
im thinking it could be a clutch adjustment or even the shift linkage adjustment. How would you know if the linkage needs to be adjusted ??
Old Feb 7, 2010 | 11:44 PM
PistonPuller
Best thing to do is the clutch pack adjustment. Sometimes the locking nut can rattle loose causing the adjusting screw to come loose. Also adjust your cable to where you have 1/8" gap when pulling the ferrule away from the perch. Manual has a good write up.
Old Feb 7, 2010 | 11:47 PM
PistonPuller
Start here
http://www.ehow.com/video_2330184_ad...utch-pack.html
Old Feb 8, 2010 | 12:49 AM
kiwideuce's Avatar
kiwideuce
mine has started to do that!! its a clutch adjustment!
Old Feb 8, 2010 | 07:02 AM
Bugsplat's Avatar
Bugsplat
I had a clunk when putting in first gear but switched to B&M Trick Shift at the recommendation of various forum members and the clunk is gone and shifting is smooth.
