Kuryakyn LED Tail light and Running light kit
Old Feb 10, 2010 | 08:43 PM
klf33's Avatar
klf33
Default Kuryakyn LED Tail light and Running light kit
Hi Guys,
I have installed the Kuryakyn LED tail light on my bike, but the 'Cycle Visions' running light/flash brake) module did not do anything to the LED light, (worked fine with the stock tail light), and was told that it is not compatible with Kuryakyn , alas, it goes back to seller.
Now.. will the Kuryakyn module they sell work with the tail light ?
Further more, I have the stock 2001 turn signals, if I wanted to install the Kuryakyn LED signals, do I need to change the stock lights ? Kuryakyn says the kit works 2002 and up and I can actually see a difference in my bulbs (my lenses do pop up without any screws as seen in the picture).
I appreciate the advice of anyone who has done this before .
REgards
Attached Thumbnails Kuryakyn LED Tail light and Running light kit-bsc_original-117s.jpg
Old Feb 11, 2010 | 06:42 PM
08Phatboy's Avatar
08Phatboy
Don't know if this really answers your question but...
The setup I'm running on my '08 Fat Boy is the Kuryakyn LED lay-down tail light and the Harley turn signal module that makes my rear turn signals running lights / brake lights / turn signals.
The H-D turn signal module works fine with the Kuryakyn LED tail light.
Hope this helps...
Attached Thumbnails Kuryakyn LED Tail light and Running light kit-dsc01840.jpg   Kuryakyn LED Tail light and Running light kit-dsc01841e.jpg
Old Feb 11, 2010 | 10:12 PM
klf33's Avatar
klf33
That gives me some hope, I was hoping someone knows the Kuryakyn piece works or not.
i will check the stealer tomorrow
I see this kit 69462-06A but it says 02 and up softails (and I am sure I do not have the flat lenses but the bullet style ones on my 02).. I will check with them tomorrow.
Regards
Old Feb 12, 2010 | 08:29 PM
kiwideuce's Avatar
kiwideuce
good luck
MR. SCOOTINN
Apr 30, 2019 04:57 PM
Mobeus102
Classic Harley Parts
Nov 7, 2016 02:59 PM
patjane
Dec 4, 2013 06:06 PM
lionsm13
Apr 18, 2010 11:44 AM
06flstf
May 16, 2008 10:24 AM
