Left Ign switch ON for 30 min while eng. stoppedke
Old Mar 27, 2010 | 06:02 PM
davisrf's Avatar
davisrf
Default Left Ign switch ON for 30 min while eng. stoppedke
Hi, my error. Battery went dead, so I'm curious what was drawing the current, but mostly curious if I screwed up something by leaving the "Ignition" switch , on the tank, ON for so long without engine running. In the old days that could fry the points (remember those??) if shut at the time. Battery is now recharging so I haven't been able to start it up again to see if any damage. Thanks for the help, Steve '07 FXSTC
Old Mar 27, 2010 | 06:25 PM
Other Sheep's Avatar
Other Sheep
The headlight is the biggest draw. Ignition should be fine, it's no different than if it was running. Bet you never do that at night.
Old Mar 27, 2010 | 06:30 PM
FLYING's Avatar
FLYING
The only damage is should just be a little dent in your pride and as far as why it went dead the biggest draw would only be the lights,so this is a inexpensive lesson!
Old Mar 27, 2010 | 07:06 PM
mplecha's Avatar
mplecha
like the other fellas said - the headlight killed your battery. Turn the ignition off! I don't use the run switch. I turn it off and on with the switch on the tank. Problem solved!
Old Mar 27, 2010 | 08:57 PM
davisrf's Avatar
davisrf
Thanks guys !! Relieved to know all OK, and yes, also forgot that the headlamp was on thus the battery draw. safe rides, Steve
Old Mar 28, 2010 | 07:43 AM
tk353's Avatar
tk353
i did that once. best to slow charge the bike over night because it can burn out your charging system if the battery is not up enough
Benway
Aug 20, 2013 09:52 AM
PKS98S
Sep 3, 2012 08:20 AM
Junior_co
May 21, 2012 10:41 AM
Chicagosong
Jun 18, 2010 08:49 PM
jimbobob
May 15, 2009 08:17 PM
