Handle bar wire connectors
Old Apr 4, 2010 | 07:52 PM
2006FLST's Avatar
2006FLST
Default Handle bar wire connectors
Okay might be getting new bars (yet again). For my current internal wires I did the old cut, solder, heat shrink method. It was not until after that I learned that you can simply disconnect by moving the tank back. Now I know I will have enough wiring but here is my question. If I pull all the connectors out can I get those wires with the connectors through the handles bars. That would make my life much easier!!!!!
Old Apr 4, 2010 | 07:55 PM
matt816's Avatar
matt816
i just used an extension kit on my bars. didnt have to run the connectors through the bars, just to reach the deutsch plug. unless the hole in the bars is pretty damn big, i think itd be a pain in the *** to cram em all through
Old Apr 4, 2010 | 08:02 PM
2006FLST's Avatar
2006FLST
I hear you. I really don't mind cutting in again. I am just trying to do it as easy as possible.
Old Apr 4, 2010 | 08:05 PM
DR. V-TWIN's Avatar
DR. V-TWIN
Former Sponsor
That really depends on if the point where you soldered the extensions will fit through the bars. Most people stagger their splices so they will fit through.
Old Apr 5, 2010 | 07:22 AM
Nickrc3's Avatar
Nickrc3
+1.
Old Apr 5, 2010 | 09:05 AM
Damage_Inc's Avatar
Damage_Inc
It depends but I think it would be a p.i.t.a to pull them through now unless you did a perfect job on those connections. I think "easy as possible" for you now would be to cut and splice(again). I took mine apart at the connector and pulled them through a drag bar. It wasn't difficult but it was pretty tight and I was only going through the bar not the riser. I couldn't see doing it with a bunch of soldered connections.
Bochawa72
Jan 12, 2019 05:38 PM
Nielsds
Feb 11, 2014 10:59 AM
DJY
Jul 9, 2013 06:04 AM
marvo75
Apr 24, 2013 08:34 PM
HDF Tech
Jun 25, 2005 06:46 PM
