Calling all FatBoy Lo Owners
Cheers
Matt
I can't speak on these new parts, everything I used was the older stuff and pieced together at that. All I can say is there is a definite difference in width between the shields for aux lights and those without. The aux lights I used add an extra 2" or so to the total width across the front end.
For these newer parts I'd assume they would say if they are for use with aux lights or not. The traditional king size shields were different for with or w/o aux kits in the catalogs, pretty easy to get the right one.
According to your part numbers, the original one you bought will not work with aux lights. The new part number you gave is for aux kit and as you are finding you can't buy just the hardware new from HD.
You could always sell your original shield to help pay for the new one. Other than that, go with any king sized shield designed for aux light kits and buy off ebay for less than dealer prices. The shield I run now I got for $100 shipped and was in almost perfect condition.
In between a dealer contacted me after reading my post - not sure though if 295 bucks for just the mounting hardware is a such a good deal...
Looks like I am going to keep an eye on ebay in Europe for some solution, if a good deal for a windshield with aux light brackets comes up - all the better
Thanks for your help!
Cheers
Matt
https://www.hdforums.com/forum/softa...t-to-lift.html
Anyways, I took the spacer they sent me (1/2"), and chopped it a little larger than in half..so something between 1/4" and 1/6", so I still get a partial lift in the rear, but the seat slides back on perfectly without issues.. DKCustoms actually sent me a refund on the product since they didn't know I wouldn't be able to use it. Great customer service right there! The biggest issue, with TNB pointed out, is that a lot is exposed around the horn and the engine mount on that side of the bike.. may be worth it to pull the mount off and paint it black or something.. mine is oxidized pretty badly, so i'd have to do some serious scrubbing on it first..and the second biggest issue is that once the tank is lifted up, you really see how dirty it is under there.. there were a ton of dead bugs up under the tank and stuck on the rocker boxes where I can't reach..along with some of the bolts being oxidized again..but some simple green and a stiff toothbrush took most of it off.
As for accuracy of the gauge, it's going to be off as it is, because you're lifting the front of the tank up and pushing more fuel towards the rear..they put warnings about that everywhere, but most people who have lifted said it's not a huge difference. I only did the 1.5" lift and I think it looks really good (I'd rather have the 2" lift, but i don't have the clearance with the Streetslammers).
When I get her back outside...whenever that'll be since Mother Nature decided to stop PMSing and actually bring on some winter..I'll take some better pictures..
I figure I am going to be changing up enough stuff when I get back, why not, right? But we will see.
