How to trailer your bike?
and then covered the remainder with the tarp.....(the tarp had holes on all sides to strap to the trailer) It worked out great and he called me the next day and said everything was perfect.Make sure you have all the tie downs equally TIGHT!!!! Do one side at a time and move around the bike...then go back and tighten! Also, keep the kickstand down (but the bike straight up)...just added protection...hmmm...keep bike in 1st gear too, and not neutral.....
Hope this helps and I am sure you will do just fine!
Also, U-Haul makes a motorcycle trailer that is high on the front and sides (also an area for the wheel to go)...just another option to consider...
Good Luck!
Don't wrap it in a tarp.
Place & secure a piece of plywood in the front of the trailer, the width of the trailer and about headlight height.
Use ratchet style straps that are in very good condition, and shop rags or towels.
2 straps above the bottom triple tree, one on each side - secured at the 10 & 2 position at the front corners of the trailer
2 straps on the down tubes, secured at the 9 & 3 position on the trailer
2 straps on the swing arm each side, and secured at the 5 & 7 position at the rea corners of the trailer.
2 straps on the rear wheel secured at the 9 & 3 position at the tail-end of the trailer
Make a small wooden box from 2x6's or stacked 2x4's approx 15 inches long and 10 inches wide and cover the top with either foam rubber or carpet. Two milk crates will work, but you will need to cut them down to fit beneath the bike.
With the bike up on the trailer, slide the carpet covered box underneath the engine area.
Begin to ratchet the bike down at all strap points a little at a time until the bike is upright and verticle and the frame is securely touching the box..
Some have the bike in gear - some have it in netural
Be sure to check the straps regularly, but surely within the first 3 to 5 miles.
There is no such thing as TOO many ratchet straps.
Have seen too many know it all's bend the bars at the risers and hammered the bushings out of shape from overstressing the strapping.....
Use the reinforced portions of the frame to bear the brunt of the support.....
Use the fork lowers at the fender mount as an anchor point, the frame at the bottom of the neck, frame at swing arm pivot point are also great points to anchor your straps to.....
And don't leave the full weight of the bike on the sidestand (if you don't have a chock).....
Blackoak gives the best scenario for open trailer loading.... Great advice and it is on the cheap....
