Detachable Side plates/Sissy Bar Install
Old Apr 13, 2010 | 07:53 AM
aamodt22's Avatar
aamodt22
Default Detachable Side plates/Sissy Bar Install
I have a '06 Fatboy CVO and just purchased all I need to install the detachable sissybar, etc. First, can anyone tell me the steps I should take? Is the turn signal relocation the first step? Also, this is the step that seems the most complicated. Should this be done by a dealer or is it easy to do on your own? Thanks for the help.
Old Apr 13, 2010 | 08:22 AM
brettnbama's Avatar
brettnbama
I was just researching this as well. I don't have the parts on hand yet, but the instructions for the docking hardware for the sissy bar said you should first install the signal relocation kit.
Old Apr 13, 2010 | 09:25 AM
DR. V-TWIN's Avatar
DR. V-TWIN
Former Sponsor
Relocate signals, put on detachable hardware, put on sissy bar.
Old Apr 13, 2010 | 10:33 AM
Mordrapheus's Avatar
Mordrapheus
What the Doc said
Old Apr 13, 2010 | 11:22 AM
shooker's Avatar
shooker
easily on your own.
Old Apr 13, 2010 | 01:01 PM
Kojax's Avatar
Kojax
Angry
my dealer put my back rest on my fatboy lo 2 and half hour job they charged me 185,00 i am wainting on the black round type back it is on back order
Old Apr 13, 2010 | 01:27 PM
grimm's Avatar
grimm
when i put mine on, i didn't mess with the turn signal relocation. i took a dremel and ground away the part of the side plate that was in the way. made it slip right over the stock turn signals. had it on there for 4 years with no problems whatsoever. plus, the relocation kit leaves a bit to be desired in the looks dept, in my opinion.
grimm
Old Apr 13, 2010 | 05:01 PM
Syman02's Avatar
Syman02
Same here grimm. Took a dremel and cut off the bump that would hit the signal. I put some chrome paint on the edge to keep it from rusting. It has worked just fine, the lock for the mounting hardware has no issues clearing the signal. This is alot cheaper and easer in the long run.
Old Apr 13, 2010 | 05:22 PM
eisterd's Avatar
eisterd
grimm
damn fine idear there! I'm gonna do that
Old Apr 13, 2010 | 06:45 PM
Noles Fan's Avatar
Noles Fan
Stage III
Turn signals first. Just follow the directions in the kit. I tried to remove the pins from the signal connectors to avoid cutting and splicing the wires, it didn't work. The pins are too fat to fit thru the signal mounts. I soldered and shrink wrapped them. I don't like butt connectors where they might get wet.
