Rear sprocket not true?
Old Apr 13, 2010 | 08:51 AM
Boxer 6's Avatar
Boxer 6
Default Rear sprocket not true?
I have a question and a whole lot of concern. I was following my wife on her 02 Fatboy and noticed that her rear sprocket appeared to be not true or in other words wobbling. I had her pull over to check it out and everything tight and appeared normal. Now I am concerned that the belt can work it way off the sprocket and lock the rear tire up which would not be cool at all. Any ideas from the forum before it goes to the dealer? Thanks!
Old Apr 13, 2010 | 09:19 AM
DR. V-TWIN's Avatar
DR. V-TWIN
Former Sponsor
Your wheel is probably not lined up correctly. Adjust the belt tensioners to line it up.
Old Apr 13, 2010 | 10:01 AM
asm481's Avatar
asm481
Sprocket bolts tight? Lots of threads about loose sprocket bolts shearing off.
Old Apr 13, 2010 | 10:30 AM
Smug's Avatar
Smug
Can ya get it up in the air and run it in first gear to see if it's the rim or just the pulley? Also check to see how the belt is tracking and if there's unusual wear on the belt. Like Doc said, make sure your rim is adjusted correctly. What works best for me is taking a measurement on each side from the center of the swingarm axle to the center of the rear axle.
Old Apr 13, 2010 | 12:19 PM
Tom84FXST's Avatar
Tom84FXST
Do you have a pulley cover? That could give the appearance of a wobble.
Old Apr 13, 2010 | 08:18 PM
Boxer 6's Avatar
Boxer 6
Thanks for the good ideas guys I'll get it up on my table lift take some measurements and get a closer look. No sprocket cover.
Old Apr 13, 2010 | 10:55 PM
oct1949's Avatar
oct1949
I'd thing even if U wheel is out the pulley should still track the same path..
If its out of square a bunch then if its also out of round U could see that also.
At least check the bolts.
Has it ever been dropped, or somehow took any kind of a hit on the pulley?
Tom 84 idea is also a possibility that a cover is sprung...
anyway good luck..
sbrmike
Apr 9, 2018 10:58 AM
joejoe75
Apr 12, 2014 05:04 PM
nickel dime
May 26, 2012 03:33 PM
haak30
Aug 19, 2010 05:37 PM
wildpig1ms
VRSC Models
Aug 19, 2007 03:47 PM
