Extra Fork Oil
Old Apr 13, 2010 | 10:19 AM
Smug's Avatar
Smug
Default Extra Fork Oil
Changed out my fork oil and used the S.E. heavy. 12.5 oz. in each tube as per the service manual. Really doesn't feel all that diff. If I add another ounce or two in each tube would it help, or not such a good idea? Thoughts, and as always - Thank You very much.
Old Apr 13, 2010 | 12:34 PM
WFA's Avatar
WFA
SMUG...I'm not an expert on forks but I wouldn't over fill for fear of blowing a seal. But that's just me. I recently changed mine using HD PERFORMANCE and noted a significant difference in ride and handling. fwiw!
Old Apr 13, 2010 | 01:08 PM
MICHALISLARNACA's Avatar
MICHALISLARNACA
Default fork oil
I would not overfill the shocks because that would cause a lot of back pressure on the top seals (weakest) and would bleed out. I did mine the other day and I noticed a GREAT lot of change. My guess is that you did not put the right oil in or you did not put enough. check again
bassnman
Air Suspensions
Aug 20, 2017 10:38 AM
fenwick
Aug 3, 2016 02:24 PM
Strgzr
Apr 28, 2013 09:13 AM
shakrr
Apr 1, 2013 06:54 AM
deez nuts
17
Oct 14, 2012 05:27 PM
