Shock adjustment
Old Apr 24, 2010 | 08:00 AM
johnbasf's Avatar
johnbasf
Default Shock adjustment
http://www.fatbillscustoms.com/
I couldn't get this link to work... I did a search and everyone pointed to this link for adjusting the shocks..
Thanks
Old Apr 24, 2010 | 08:25 AM
KumaRide's Avatar
KumaRide
Yeah, that was a good link. Here ya go.
Tools:
- Shock spanner wrench
- 1 1/16 open end wrench
- White paint pen
Parts:
- Adjustable shock (Stock, Long or with Lowering Kit).
Instructions:
1. Determine whether your suspension is too stiff or too soft for your liking. Take into consideration whether or not you will be riding solo or 2-up most of the time.
2. With a white paint pen, put a mark on the face of your adjuster plate at the 6 o’clock position. This will be your starting position. Do this to both shocks
3. While holding the adjuster plate in place with the spanner wrench, break the adjuster nut free from the adjuster plate by turning the nut counterclockwise
If you are adjusting for a heavier weight (stiffer ride):
A. Continue to turn the adjuster nut counterclockwise (the nut will move towards the front of the bike) until it stops.
B. Now using the spanner wrench, turn the adjuster plate counterclockwise no more than 4 complete turns. Count the number of times the white mark crosses the 6 o’clock position.
C. While holding the adjuster plate in place with the spanner, tighten the adjuster nut up against the adjuster plate by turning the nut clockwise.
D. Now repeat the exact process with the other shock.
If you are adjusting for a lighter weight (softer ride) :
A. Now using the spanner wrench, turn the adjuster plate clockwise no more than 4 complete turns. Count the number of times the white mark crosses the 6 o’clock position.
B. While holding the adjuster plate in place with the spanner, tighten the adjuster nut up against the adjuster plate by turning the nut clockwise.
C. Now repeat the exact process with the other shock.
Note: - When you turn the adjuster nut - only the adjuster nut should turn.
- When you turn the front nut - only the front nut should turn.
- When you turn the adjuster plate - the canister might turn too. Some people find it easier to turn the adjuster plate and the canister at the same time.
- If the canister turns or not - it doesn't matter - the canister does not affect the outcome.
There are a limited number of threads. Count the number of threads visible
Use the "rule of thumb" chart below:
- 4 threads = Preloaded for a softest spring (<180 lbs)
- 3 threads = Preloaded for a softer spring (181-237 lbs)
- 2 threads = Preloaded for a softer spring (238-293 lbs)
- 1 threads = Preloaded for a stiffer spring (294-349 lbs)
- 0 threads = Preloaded for a stiffest spring (>350 lbs)
Old Apr 24, 2010 | 06:18 PM
johnbasf's Avatar
johnbasf
Thanks, I'll do this tomorrow. Got the wrench today..
Old Apr 25, 2010 | 07:36 AM
tk353's Avatar
tk353
i was going to adjust mine from stock but that was 50,000 miles ago. maybe some day
Old Apr 25, 2010 | 02:59 PM
johnbasf's Avatar
johnbasf
Got them adjusted. I had to grind the wrench tips down about a 1/4" so the open end wrench would stay on the jam nut. I'll ride soon to see how big a difference it makes.
Old Apr 25, 2010 | 03:47 PM
tk353's Avatar
tk353
be sure to let us know
Old Apr 25, 2010 | 04:10 PM
soft 02's Avatar
soft 02
Not trieng to steal this thread but does anyone have the spanner tool for adjusting shocks. If so can someone give me the mesurments of the prongs outside and inside thanks.
Old Apr 25, 2010 | 06:48 PM
johnbasf's Avatar
johnbasf
2" x 1 3/8"
Old Apr 25, 2010 | 06:56 PM
soft 02's Avatar
soft 02
Sweet. thanks johnbasf. I'm going to make one tomorow.
Old Apr 28, 2010 | 05:25 PM
johnbasf's Avatar
johnbasf
Rode today..Ride felt better. I'll get the wife on there Saturday and let you know after that.
