Yes you do!!! Go with a good 2 into 1 for the street!!!
OK, lets say I just HAVE to have the true dual fishtails.... which bolt in cam do you think would best suit these pipes and a SE a/c?? stock heads and stock compression - Andrews 48H or TW6-6 +4* adv???
You will not lose power compared to stock. But, fishtails are notorious for robbing power compared to a good performance pipe. If they are duals but not fishtails then it will still likely cost you a little power compared to a good performance pipe but not as much loss as fishtails.
What is it about the fish tails exactly that causes the problem?? Too restrictive??
The point is that I am running true duals regardless of losses in performance..... just have to figure out the best ways of getting soome of that performance back - ie good choice of cams...
