Need help finding true duals for 1994 FLSTN
Old May 21, 2010 | 12:40 AM
kkiley's Avatar
kkiley
And that's why I read this forum. Nice job Samson Tech!
Old May 21, 2010 | 05:48 PM
Cruisin1966's Avatar
Cruisin1966
Now the hard part begins. Finding a set of the S-220 headers. I would love to find a used set to have ceramic coated so i could run them without heat shields
Old Apr 9, 2011 | 05:03 PM
franciscoml's Avatar
franciscoml
Stage II
Default FLSTN Duals
Checking in on the duals for the 1994 FLSTN from the original post. I am looking at a 94, and that is something I would want, but am running into the same obstacles.
BTW, I am looking at a 94 FLSTN, 11k, a good bit of chrome, really good shape. Is 10k a fair price for that? It does not have the original bags.
Old Apr 10, 2011 | 03:05 PM
Panasoffkee's Avatar
Panasoffkee
Default 94 flstn
10k is a fair price. My 94 is absolutely beautiful with one big load of chrome accessories on it. It wins many trophies.
Old Apr 10, 2011 | 07:40 PM
franciscoml
Stage II
Were u able to get the duals on it? That is my preference, but i also like the vance and hines 2 into 1 pro-pipe. Not sure if that would spoil the vintage look.
Old Aug 21, 2011 | 11:50 PM
Panasoffkee
Default FLstn Duals
Haven't located a reasonable set or a used set in nice condition. $800 seems a little extreme for a couple pieces of pipe. I'll keep looking now that I know they can be mounted.
Old May 22, 2019 | 12:51 PM
btm2069's Avatar
btm2069
4th Gear
Originally Posted by Samson_tech
the 94 and earlier frame does not have a mounting area on the left side of the frame and the 95 and newer does. this is what is different by the two years. many people have mounted Samson true duals to 94 and earlier bike with modifications to the left side of the frame. the mounting location would be on a forged portion of the frame directly to the left hand side from the right side bracket mounting location. it is curved in that area on the left, not flat. two holes 3/8 - 16 holes will need to be drilled with the mounting bracket as a template with the exhaust mounted so you get the holes drilled in the right place. mark the locations with a hole punch then remove the exhaust. the bracket is straight and will need to be bent to form to the frame or fabricate a wedge to fit the frame so the bracket doesnt have to be bent. we recommend the person making this modification have fabrication experience.
thank you,
JR
My 1996 FLSTN had to be drilled and tapped as well. Just did it this morning.
zukeepr
Exhaust System Topics
Jul 9, 2013 10:51 PM
chefskeeter
Jun 16, 2011 11:34 AM
stratplexi
May 16, 2010 06:18 PM
Tn.Heritage
Oct 10, 2005 09:53 PM
