Wheel Bearing or ???
Old May 26, 2010 | 08:24 PM
tk353's Avatar
tk353
be sure the inner spacer is not loose and that it does not bow the bearings outward either
Old May 27, 2010 | 07:13 AM
Damage_Inc's Avatar
Damage_Inc
The inner spacer had some play when I removed the wheel and there is a about 1/4" now that the bearings are replaced. Call me crazy but I don't think you'd want to have it tight against the inner race of the bearing.
Old May 27, 2010 | 07:46 AM
tk353's Avatar
tk353
yes you want them with in 3/1000 in. i has that issue on the front because the rim was cut wrong. if not snug it will cause the same issue. time to call Harley customer service
Old May 27, 2010 | 07:55 AM
Damage_Inc's Avatar
Damage_Inc
I know a couple real good indy's and I'm gonna make some calls today.
Old May 27, 2010 | 07:58 AM
tk353's Avatar
tk353
harley covered replacing my wheel after the warranty expired but i had it replaced also during the warranty 2 time.
Old May 27, 2010 | 08:57 AM
Damage_Inc's Avatar
Damage_Inc
Well luckily I was too lazy to install it last night otherwise I probably would have screwed it up real good again!! I still had the wheel in the back of my truck so I just whipped over to the custom builder that has a shop near my work. He slapped a handy little tool on there and took up the slack between the bearing and the inner spacer.
Thanks tk353, if it wasn't for you I would have left it alone and right back to square one in no time!
Old May 28, 2010 | 06:36 AM
Damage_Inc's Avatar
Damage_Inc
I put it back together last night and she rides as smooth as silk now, no wobble, no grinding.
Thanks again for the input guys.
Old May 28, 2010 | 07:36 AM
tk353's Avatar
tk353
ride safe
Old May 28, 2010 | 09:32 AM
cwsharp's Avatar
cwsharp
You should only torque the axle to spec. The spacer shouldn't be 'tight'.
Old May 28, 2010 | 09:36 AM
Damage_Inc's Avatar
Damage_Inc
Yep I torqued it to 65ft/lbs
FISM
Jun 27, 2016 11:34 PM
Greenblood
Apr 16, 2016 06:36 PM
FXDForbes
Jan 16, 2014 07:41 AM
RobPic
Jul 21, 2011 02:48 PM
joesride
Jul 6, 2011 08:20 PM
