Electrical problem
Old May 21, 2010 | 05:44 PM
aviscomi's Avatar
aviscomi
Default Electrical problem
As soon as I turn on the ignition switch on my 2008 Nightrain I keep "blowing" the turn signal/brake light/horn fuse. I spent the last 4 hours checking for shorts and couldn't find anything. This started happening "out of the blue"; I haven't made any modes on this bike in over a year. Any thoughts?
Old May 21, 2010 | 05:47 PM
bear68's Avatar
bear68
I have seen burned out bulbs short when the filament falls and makes a connection where it shouldn't. Simple test to pull the bulbs and see if the fuse stops blowing.... Just a thought....
Old May 21, 2010 | 06:09 PM
aviscomi's Avatar
aviscomi
LED turn signals & brake lights...thanks for the idea though
Old May 22, 2010 | 08:34 AM
handyhoward's Avatar
handyhoward
There's a short in the system somewhere. Start with doing maintenance on the switch... clean and regrease with electronic grease. If that doesn't do it... start working your way back to the battery from each of the parts serviced by that fuse... I use a voltmeter with needle points.
Old May 22, 2010 | 10:36 AM
tk353's Avatar
tk353
have you pulled the seat? the wires to the tail lamps are not protected thru the fender hole. if the harness get slack it kets the connector fall inside
Jared0869
EVO
Jul 23, 2017 11:59 AM
PSCarter
Electrical/Lighting/Alarm
Sep 22, 2015 08:28 AM
GLIDEGASM
Apr 9, 2014 06:29 PM
zxsport30
Oct 31, 2008 09:13 PM
SamStone
Jun 25, 2006 08:22 PM
