It is not a hard mod. What I did is trace the back of the bag onto a cardboard template. Then transfer that to a 10 or so gage piece of sheet metal. The holes are already in the bag so use those to mount the bag to you plate. I put the flat part of the screw head on the inside of the bag so the nut would not snag on anything. I did not use the couple nuts like some did, I welded one inch spacers onto the back of the plate and used the belt guard holes to mount it to the swingarm. I have put soe pretty heavy stuff in te bag and have not had a problem. Sorry I don't have pics, I just moved to another state and they are on my other computer sitting in storage. Enjoy your bag.
Either way, I love having a bag there and stick my lunch in it for work, or misc stuff for day trips.
If it's a detail you dont like, then by all means you could run straps or bracket, or whatever. I've had many compliments on my bags, but no one has ever wedged their head behind there and said "man! those zip ties look like azz!" Lol
Enjoy and let us know what you come up with.
Did you design those bags yourself, or did Shaun? They are really nice!
Everything is so tight to the swingarm I doubt I can get a better shot.
I basically did what others did. I used 1" coupler nuts for the forward/top and lower chain guard mounts. The rearmost chainguard mount, I used a 3/4 " spacer and a 1.5 inch bolt. This all allows the bag to sit approx 1/8th inch off the swingarm. Inside the bag is where I used plexiglass.
All hardware is 5/16 and in assembly order. (I painted all visible hardware black)
8x11 plexiglass sheet cut to fit inside bag.
Lower mount
3/4" set screw or stud (threads into chain guard/frame)
two spacer washers
1" coupler nut
Fender washer (against the bag outside)
3/4" button head bolt and a washer (inside bag)
Front mount upper
1" bolt (replaces original shorter bolt, reuse existing washer)
two spacer washers (other side of chain guard)
1" coupler nut
Rear mount upper
Begin inside bag
1.5" bolt and a washer
Fender (or smaller) washer against the bag outside)
3/4" spacer
Thread into existing hardware in chain guard.
This looks awesome Thanks for the info
Stop by the drinking thread on Friday and let me buy you a beer
That mount looks great meatsack. I'm going to have to do that when I get some time. When I got my bag I just wanted to put it on and ride. Your mount is really the way to go though.
