crossbones
Old Dec 24, 2010 | 02:07 AM
  #111
colonelangus1's Avatar
colonelangus1
Default update with pics
had some spare time so i finished up the taillight wiring complete with harley connectors ofcoarse i also added a negative to ground the light directly .looks wierd because the light comes with a red and black wire but both are hot .
stopped by Aurora Electronics and had the plug wires made.
Old Dec 28, 2010 | 10:18 AM
  #112
colonelangus1
the xbones fender has a chrome arm attached to an axle spacer on the right side.the heritage has a spacer but it wont fit on the bushing that is now used on the xbones lower right side rocker.i could remove it but after carefully reading the manual and studying the pics .i came to the conclusion the xbones system is an upgrade as the heritage springer was and is known for riding like a roller skate <except when new or recently serviced>.
i say this because ive seen a few now that ride rigid the front end barely moves.when torqueing the axle nut the rockers can bind on the axle spacer and combined parts making it basically dead .so with that being said i cut the axle spacer off the arm going to the fender.ill smooth it out and powder coat it black ..
ok heres a pic of the bushing and how far it sticks out of the lower rocker.that is the biggest difference
Old Dec 28, 2010 | 05:19 PM
  #113
colonelangus1
Default oven fresh
heres the spacer fresh from the oven i think it will look fine
Old Dec 28, 2010 | 09:39 PM
  #114
snook592's Avatar
snook592
Old Dec 29, 2010 | 01:09 PM
  #115
JakesDad1's Avatar
JakesDad1
Old Dec 30, 2010 | 03:38 AM
  #116
colonelangus1
this is where i got tonight
front fender hubs,and fender light
fuel pump ,fuel gauge,and gas cap
rear fender tombstone taillight,wiring harness,seat bracket,ecm mounting plate,
Old Dec 30, 2010 | 03:01 PM
  #117
colonelangus1
Default update with more pics
well got up today no snow so no dough took a look at the progress i made last night and decided to finish it up
installed struts,signals and strut covers
completed assembly
i used dialectric grease on all connections pretty much forced it in untill it sqeezed out
i know wiring looks a little messy but its laying flat and has zap straps holding them together
Old Dec 30, 2010 | 03:46 PM
  #118
RevMatt's Avatar
RevMatt
Default Bad *** custom Bones!!!!!!!!!!!!!!
completed assembly
That is going to be one bad *** custom Bones! When do you hope to complete it?
Old Dec 30, 2010 | 03:51 PM
  #119
Lucky22's Avatar
Lucky22
Sherrif, you keep the paint job this clean?
Old Dec 30, 2010 | 05:39 PM
  #120
colonelangus1
thanks hopefully sooner then later probably in the next few days or so i just need an extra set of hands lol
well it is fresh paint so it should be clean ,but its very dusty from sitting cant really wash it yet
