Check engine light
Old May 28, 2010 | 09:20 PM
the blob's Avatar
the blob
tighten exhaust up at the heads. if its popping you may have air getting sucked into the pipes and throwing the readings off on the 02 sensors, hense low voltage or lean codes. also you should replace the ex.port gaskets when intalling new pipes.
Old Jun 26, 2010 | 11:06 PM
jimsheila's Avatar
jimsheila
3rd Gear
It was great finding this code diagnostics page greatly appreciated. Is the code po563 the same for 2006 softtall heritage classic and if so (P0563 Battery Voltage High) is this a serious problem? thank jim
27freethrows
Nov 11, 2012 09:45 PM
SevieC
Oct 25, 2012 07:04 PM
FiremanJeff
Oct 19, 2012 09:52 AM
gunner11
Nov 9, 2010 02:20 PM
Fish Slapper
Apr 6, 2009 06:09 PM
