DIY quiet baffles
Old May 28, 2010 | 07:12 AM
bloomington g's Avatar
bloomington g
Default DIY quiet baffles
I posted a message on this topic in the engine/exhaust forum and I thought I would check here also.
I use BCT baffles, but I am looking for some quiet baffles for longer rides. Anyone ever made their own quiet baffles? Is there any way to modify standard V&H longshot baffles into quiet? I want to try using what I already have vs. buying. Unless there is someone that wants to sell me some quiets cheap...
Old May 29, 2010 | 06:21 AM
dkpawlowski's Avatar
dkpawlowski
The main difference between the V&H quiet baffles and normal is the quiet baffles have a closed end while the normal are straight through. You could weld a disc on the end of the regular baffles. Also, you can experiment with various amounts of wrap.
Old May 29, 2010 | 09:01 AM
tk353's Avatar
tk353
the quiet baffles are a baffle inside a baffle. you can make your own with muffler pipe and freeze plugs and packing. you will need to retune the engine
Old May 29, 2010 | 10:48 PM
Brian_D's Avatar
Brian_D
Yeah, the V&H Quiet Baffles have a plug washer welded inside the middle of the baffle to force the exhaust flow and sound around. You could probably accomplish the same thing with a washer welded in.
dohadex
Exhaust System Topics
Jan 26, 2011 03:02 PM
gqchynaboy
Sep 3, 2008 09:10 AM
falsealarm
Jul 9, 2007 07:58 AM
Larryc5079
Jun 15, 2007 09:05 AM
sfcmo357
Dec 6, 2005 05:03 AM
