Starter problems Softail heritage Springer
Old May 31, 2010 | 08:37 PM
sf012's Avatar
sf012
Stage II
Default Starter problems Softail heritage Springer
Have been having a potential problem with the starter kicking in when button is pushed, but hear a squealing prior to engine turning over. Haven't taken apart, but sounds like a clutch is not engaging as it should. could it be the overrunning clutch and are they available as an item from Harley?
Old May 31, 2010 | 11:57 PM
In Memoriam Citoriplus's Avatar
May our Moderator Rest in Peace
Pull the starter and check it out, its sounds a little like the over-running clutch is slipping or the solenoid not engaging properly.
I believe the clutch is a replaceable part as its listed as a subassembly in my parts manual. It lists several different part numbers however so your going to have to figure out exactly which one you need before you can get the right one if its really screwed up.
If its the solenoid the manual lists a repair kit for that.
Oldgreazer
May 9, 2015 07:57 PM
Stape
Feb 19, 2012 08:22 PM
sf012
May 31, 2010 09:02 PM
gigiflip
EVO
Jan 31, 2008 05:06 PM
samuel
Jun 14, 2006 07:03 PM
