Scrapping Noise on Decel
Old Jul 22, 2010 | 07:01 AM
handyhoward's Avatar
handyhoward
Proper alignment of the rear wheel and drive belt is easy to do... that's why there are adjusters on both side of the axle... measure from the middle of the swing arm pivot bolt to the middle of the axle nut on both sides... if it is the same then the alignment is correct. If it is not the same, then adjust it until it is. The belt should run around the pulley going forward approximately centered... by the way, do not use belt dressing on the belt.
Old Jul 22, 2010 | 11:04 AM
FastHoss's Avatar
FastHoss
Yeah all belts move from side to side with a forward or reverse motion.
Old Jul 22, 2010 | 08:30 PM
jlasoftail's Avatar
jlasoftail
I can't say for sure without hearing the sound, but I know I had a similar noise on decel last year. Went right to dealer and he said "don't worry, that's normal" I thought, yeah right, something is big time wrong here, but left it alone, thinking at least i have warranty when something finally lets go. Anyways, a few thousand miles later, it went away and never came back. How many miles do you have on your bike? Oh, and no it wasn't there when I first bought the bike. It just kinda came and went. Sry if that's not much help.
toddman015
May 13, 2023 11:08 PM
Irsh
Mar 19, 2016 11:10 AM
beaucipher
Aug 2, 2014 12:07 PM
Kcar1020
Feb 16, 2010 11:01 AM
2008FLHP
Jul 15, 2008 02:29 PM
