Why pull the gas tank...
Old Jun 8, 2010 | 02:38 PM
cryan9's Avatar
cryan9
The other thing you have to remember is that you have to remove and re-install new throttle/idle cables. It is alot easier to do when the tank is out of the vay because the cables run through clips along the frame backbone up until just behind the throttle body. It makes working on everything alot easier.
Old Jun 8, 2010 | 03:35 PM
chunks's Avatar
chunks
Thanks all. Got my question answered
Old Jun 8, 2010 | 07:22 PM
RedBen's Avatar
RedBen
If you don't feel like draining the tank, like some of the others said, you don't have to remove the tank. I slid mine back with a mostly full tank. It's just a little heavier to slide. One thing to watch out for if you slide it back is the clamps on the crossover line scratching the top of the motor.
Old Jun 10, 2010 | 07:27 AM
Plasteredcat's Avatar
Plasteredcat
all great answers guys as usual. Cable lengths for 16" apes with 1" risers? can some one please share. My RSD's finally after over a month showed up.
Thanks
Old Jun 10, 2010 | 09:23 PM
In Memoriam Citoriplus's Avatar
May our Moderator Rest in Peace
One thing to remember, if your screwing around with the tank AT ALL.
Pull the fuel line to the injectors (left side of tank) off BEFORE you do ANYTHING.
I can say without fear of contradiction that if you fail to do it you WILL, like a lot of other guys, myself included, be looking at about a $50 bill for a new fuel line.
billbuzz
Jan 16, 2012 08:46 PM
BravoFireRescue
Aug 14, 2011 06:54 AM
cacasal
May 4, 2011 11:11 AM
paud
May 7, 2010 08:16 AM
GNR
Sep 16, 2008 11:44 AM
