Front Fender Tip Light
Old Jun 10, 2010 | 08:21 AM
Shakeydeal's Avatar
Shakeydeal
Why not just ditch the light, since you probably have to reapaint the fender anyway. Those things look tacky.
Shakey
Old Jun 10, 2010 | 12:52 PM
boomer1964's Avatar
boomer1964
6th Gear
I should update. Thank you to everyone because I need all the help I can get!!
I could NOT remove the pins. They were in there so tight I could not get them free. So - I cut the wires and will splice them back with the heat wrap to seal them good n tight. I HATE doing that because you can really affect the leads badly because they are so exposed under that fender, but in this case I simply did not have a choice.
The dent has been visibly removed and repaired. No need to repaint and you almost cannot tell there is even a dent in it, until you run your hand over it and just a slight ripple can be felt. The body shop folks even buffed the fender for me to remove some of the buff marks from a small tool bag that must have been on the bike before I bought it. It almost looks new.
At some point I DO want to ditch both front and rear fender lights. I like the fender clean. Gives it a sharper crisper line to it, and there is less to worry about. But - thats later. Once I replace the springs and the fork oil, I should be ready for some riding over in Michigan at my folks place next month.
I should have it all reassembled tonight.
SecondGear
2014-2024 Touring Models
Mar 31, 2016 07:55 PM
Nellybelle
Jan 12, 2013 08:36 PM
clayharley
Mar 6, 2010 12:20 AM
longlakehouse
Electrical/Lighting/Alarm
Oct 23, 2009 07:23 PM
timvan
Mar 20, 2009 12:58 PM
