fuel or ignition problem please help!
Old Jun 15, 2010 | 08:29 PM
Rex_Vaginas's Avatar
Rex_Vaginas
Default fuel or ignition problem please help!
hi, i have an 06 night train. it has a stage 1 from fuel moto usa with a pc III. had the bike run a dyno a few weeks ago and the numbers were good. Parked the bike for a few days, went to start it and it would not fire up, just kept turning over. kept trying to start the bike for about ten minutes and it eventually fired up, started out at a low idle then went back up to a healty idle. lost power a couple times on the highway when going out to pass vehicles but other than that the bike ran good...then yesterday bike started and ran fine. Today couldn't get it to fire up again and when i eventually did it went to a real low idle let out a puff and shut down. unhooked the pc III and went back to stock and the bike started fine. hooked the power commander back up right after, and the bike fired up and ran fine. what the hell is going on?? any help would be appreciated! is this something electrical failing, or a fuel problem? i can't really take it into the dealership because the bike runs fine 80% of the time and just started doing this. thanks!
Old Jun 15, 2010 | 08:50 PM
Rex_Vaginas
also i checked the codes and got nothing...
Old Jun 15, 2010 | 09:50 PM
rdoucet's Avatar
rdoucet
I would start with the basics; change plugs and wires - get fresh fuel also; depending where you last fueled up you could have water in the fuel.
Old Jun 16, 2010 | 08:59 AM
tk353's Avatar
tk353
leave the pciii off and see if the issue returns. if not then call fuel moto. if it returns then you can start with fuel, plugs, dealer
Old Jun 16, 2010 | 01:26 PM
mike06train's Avatar
mike06train
Sounds like the PC. Buddy of mine had that problem and it was his PCIII. Like anything else, sometimes you get a bad one.
TeeJayEe
General Topics/Tech Tips
17
Mar 30, 2017 02:35 PM
Harley Limited
Aug 31, 2015 02:39 PM
MAJOR
Oct 2, 2013 11:56 AM
kennyjohn
Jun 15, 2010 05:14 PM
Kowalski
Jun 10, 2010 09:26 PM
