Vibration - what vibration?
Old Jun 22, 2010 | 01:32 PM
mplecha's Avatar
mplecha
Default Vibration - what vibration?
I had a bit of a tingle in my bars that started last fall. I looked around for it from time to time, but only recently did it get much worse. My left side mirror and grip vibrated quite a bit at certain rpms sometimes. It was hard to figure out the cause since it was very intermittent. Today, I pulled my primary apart. Everything looked fine. My comp nut even felt pretty tight. When I got my rotor off (which I had suspected for a while), I found the problem. Apparently, the comp nut was just shy of tight enough. The teeth on the rotor were worn down significantly. The vibe was the rotor wobbling back and forth on the shaft. I feel lucky it didn't damage anything else. My stator is ok as is the bearing in the case. I just happened to have an extra rotor here in my shop, and now, all is good again. I just wanted to post this in case someone else was chasing a vibration. Check your compensator nut and rotor!!
Old Jun 30, 2010 | 06:25 PM
mplecha's Avatar
mplecha
guess I spoke too soon. it came back the next day. sigh...
Old Jun 30, 2010 | 07:39 PM
gforrest2's Avatar
gforrest2
Off topic and maybe a coincidence, but I changed out my Longshots for some Big Radius and now it seems my bike is vibrating more. I mainly feel it in the floorboards. Maybe just the pulse out of my now shorter exhaust is causing the problem or maybe it's just all in my head. Anyone else experience this?
Old Jun 30, 2010 | 07:42 PM
m i k e's Avatar
m i k e
might have a hairline crack in yer apes
Old Jun 30, 2010 | 07:52 PM
Jackie Paper's Avatar
Jackie Paper
Default Rotor
The rotor spline is a weak link in the older softails. The compensator nut does not need to come loose. Given enough max rpm shifts and rough down shifts will spin it thru the splines. Mine was only being driven by the compensator spring for over two years and I only caught it after the chain started hitting the sprocket on the edge. Check out my albums on it. I think the newer motors have serrations like the clutch basket
0maha
EVO
26
Mar 21, 2017 06:11 AM
ridetohell
Electrical/Lighting/Alarm
Aug 9, 2015 07:55 PM
Yankee Dog
EVO
Jul 4, 2015 02:21 PM
Softy
Sep 18, 2007 03:14 PM
Evilution
Nov 8, 2006 09:33 PM
