brake light constantly on
Old Aug 25, 2006 | 11:42 PM
irishfastback's Avatar
irishfastback
Default brake light constantly on
I have an 06 Night Train...The brake light is constantly on when I turn the bike on. Any thoughts on this???
Old Aug 25, 2006 | 11:44 PM
Terry TK's Avatar
Terry TK
Big Kahuna HDF Member
Default RE: brake light constantly on
The rear brake switch is bad. This is a common problem and is an easy fix. I'm not sure where the switch is on your bike but it's usually on the right side of the lower frame.
Old Aug 26, 2006 | 11:52 AM
JamieWG's Avatar
JamieWG
Have you recently changed the throttle grip or had the front brake lever off the bike? Common prob is that you need to watch the brake switch on the front lever. The little button snaps off easily.... result is, you need a new switch at the lever.
Old Aug 26, 2006 | 02:58 PM
snowyhog's Avatar
snowyhog
The little copper V bit that slots into the rh side of the pressure switch ,has probably poped out . Especially if you have had apart
Old Aug 26, 2006 | 06:14 PM
HOGWYLDPR's Avatar
HOGWYLDPR
One quick way to check is to disconnect the rear brake switch on the right rear side of the frame. If it you turn on the bike and the brake lights are still on, then it's your front brake switch. Had this happen to me. Hope this helps.
Old Aug 27, 2006 | 03:39 AM
irishfastback
Hey guys,
Thank you for all the replies...It was the brake switch...
Thank you again
punkmxcn
May 26, 2020 08:51 PM
rideamap
Electrical/Lighting/Alarm
Sep 16, 2014 01:00 PM
cweiss
Aug 17, 2013 07:59 PM
Joanrava
Wheels/Tires
Jan 23, 2011 12:02 AM
tidefan60
Aug 7, 2010 09:48 AM
