Brake light prob
Old Aug 17, 2013 | 04:12 PM
cweiss's Avatar
cweiss
Default Brake light prob
Light stays on does not get brighter with pull of brake lever or push of pedal. Checked fuse it is good. I assume I need a part and I cant remember the name of it. Any help would be appreciated.
Old Aug 17, 2013 | 04:55 PM
btsom's Avatar
btsom
2 switches operate the brake light, the front brake lever switch and the rear brake switch. It is most common to break the front lever switch when removing the brake lever or the switch box. There is a very easily broken plastic button on the end of the switch which contacts the brake lever. If that is broken off, it results in your problem as without that button, the switch doesn't get pushed back into the housing far enough to interrupt the circuit and turn off the brake light. Inside the switch box there is a little V shaped sheet metal spring which pushes on the other end of the switch and keeps it against the outer end of the switch box. If that spring broke or fell out, you can have your problem. Usually, the rear switch fails in the off mode, but it can get stuck the other way also. It is an old fashioned pressure switch which works on brake fluid pressure. It is mounted near the back end of the chrome transmission cover in a plumbing fitting.
Removing a wire from the rear brake switch should break that circuit and turn off your brake light IF that switch is the problem. If the front brake switch is the problem, pushing the brake lever hard against brake off stop might turn off your brake light for trouble shooting purposes. Have you recently changed handle grips or fiddled with the front brake lever or the switch box?
To the best of my knowledge, the rear switch cannot be repaired, it must be replaced. The "shade tree" fix for the front switch varies. The "official" fix is replacement and then you have the very tender plastic button to break off again. I have glued a replacement little plastic button on the lever end of the switch, others have put a small screw into the brake lever where the switch contacts the little screw head and is pushed in far enough to turn off the light. Good luck with your project.
Old Aug 17, 2013 | 06:07 PM
Bugsy's Avatar
Bugsy
Are you saying it's stuck on bright, or it's not getting brighter when the brake is applied?
Have you checked the bulb? Perhaps one of the filaments is burned out?
If it's stuck on, see btsom's post above.
Old Aug 17, 2013 | 07:59 PM
cweiss's Avatar
cweiss
It appears to be stuck on bright yes. I changed the bulb just to make sure.
toadster911
Electrical/Lighting/Alarm
Oct 4, 2017 10:18 AM
rideamap
Sep 16, 2014 01:00 PM
Joanrava
Wheels/Tires
Jan 23, 2011 12:02 AM
tidefan60
Aug 7, 2010 09:48 AM
irishfastback
Aug 27, 2006 03:39 AM
