brake light stays on
Old Jun 6, 2013 | 11:06 AM
acd118's Avatar
acd118
These are all excellent responses, but I'm also going to add that my bike was doing the same thing and I found a few other things. First, the plunger in the front master cylinder was all gummed up, not allowing the plunger to push the little tab on the lever far enough out to disengage the brake light switch. You might want to check that out too. Also, the connectors on my Tri-Bar LED tail light were completely dry of grease and every time I got caught in the rain, my brake light would stay on because the water was completing the circuit. I tore apart the tail light, cleaned it up real good, put dielectric grease in the connectors, and have never had that problem again. Hope this helps.
Old May 3, 2016 | 07:28 PM
lostnawave's Avatar
lostnawave
3rd Gear
Default Pics?
Think i might have this "little tab" issue after reassembling when i changed out the handlebars. Anybody have a pics as to what im looking for? Bike is a 2002 deuce. Thanks!
Old May 3, 2016 | 07:42 PM
RANGER73's Avatar
RANGER73
Pull your lever, it's right behind it. Push it in by hand and see if the light goes off. Use the little screw repair or replace it. It's not a novice replacement.
drsnipes
Dec 3, 2023 01:18 PM
Mr Brown
May 12, 2015 07:01 PM
mrush1130
Sep 22, 2013 10:08 AM
kenward
Jul 7, 2010 01:00 PM
moblmowr
Feb 29, 2008 08:00 PM
