Stiffening shocks
Old Jul 15, 2010 | 12:38 PM
WFA's Avatar
WFA
Originally Posted by nvsteve
i also found that i could adjust the shocks with a strap wrench. By turning the body the plate moves as well. Much easier than using the tool.
strap wrench...that's a great idea!! But the shock canister and adjuster plate don't always turn together. However, they generally do.
Old Jul 15, 2010 | 02:56 PM
06Heritage's Avatar
06Heritage
Thanx for the info. I was trying like hell to just get the plate to move without the whole shock turning. Duh me .
Old Aug 1, 2010 | 07:23 PM
campdreamer47's Avatar
campdreamer47
Question Do you mean a strap wrench like you would use????
I also found that I could adjust the shocks with a strap wrench. By turning the body the plate moves as well. Much easier than using the tool.
Hi do you mean the same kind off wrench you would use to take off a car oil filter? If so could you explain in more detail??
Old Sep 2, 2010 | 10:53 AM
Clayvis's Avatar
Clayvis
I just did this adjustment last night for the first time. I bought the wrench from the $tealer for $10.95. It is a bit futzy to use, but does work. I had the bike jacked up as high as my lift would go. Then I used an open end 1 1/16 wrench to break the lock nuts loose. They were NOT loctited-thank God! I was advised to turn them out one full turn each and then test ride. I made some alignment marks to get them both even. I almost always ride solo, and I weigh 190, so what was the problem you ask? Well I have nearly 20k miles on them, and it seemed to be getting a bit too soft. I never have bottomed out, but now it feels very responsive. Me likey.
ahappydude
Jul 5, 2021 12:34 AM
VETERAN75
Apr 10, 2014 09:45 PM
slimjim1976
Apr 7, 2014 07:05 PM
ikashibi
Oct 15, 2011 11:52 PM
hd2000
Apr 1, 2006 10:22 PM
