Brake light?
Old Jul 20, 2010 | 11:22 AM
HarleyCanada's Avatar
HarleyCanada
Default Brake light?
Just wondering if any of you have had a similar problem with your brake light. The brake light stays on after my front brake has been used?. I can get it to return to running light by giving the brake lever a slight push forward? I know the problem is in the front brake lever, because when I use the rear brake everything returns to normal. My bike is an 04 FXSTS. I have read my manual, and it slightly talks about the switch. Any help would be much appreciated. Thanks
Old Jul 20, 2010 | 02:38 PM
jimmers1817's Avatar
jimmers1817
I've never had that problem but it does sound like it's the switch. Ever have the right controls off?
Old Jul 20, 2010 | 02:56 PM
07DDreamHD's Avatar
07DDreamHD
The switch is probalby ok since you can return to running lights by pushing the lever forward. Inside the controls, there is a metal strip (I think it is copper) that provides a spring load against this switch. It may be possible that that strip broke in half and is no longer providing the spring load.
punkmxcn
May 26, 2020 08:51 PM
decencyxdefied
Feb 18, 2014 11:38 PM
kjov_
Feb 10, 2013 02:08 AM
bayouboy52
Jul 12, 2009 01:48 PM
Bcspy
Oct 8, 2008 08:51 AM
