cableless throttle
Old Aug 9, 2010 | 03:51 PM
Coxbow's Avatar
Coxbow
Default cableless throttle
Hi Folks,
Did you or someone you know put a MoCo (or other) cableless throttle on your bike ?
I would like to do the same with my Street Bob.
Thanks
Old Aug 9, 2010 | 04:36 PM
Nautilus's Avatar
Nautilus
Wink
I assume that by "cableless throttle" u mean an internally wired throttle...
there iare no cableless throttles... every single one has to be connected to the throttle body or an electric module that receives the signals from the throttle to the throttle body...
Am I right?
Old Aug 9, 2010 | 05:44 PM
1911NT's Avatar
1911NT
i think exile choppers makes what your thinking of
http://www.exilecycles.com/index.php?section=37
Old Aug 9, 2010 | 07:09 PM
Fightn_Tiger's Avatar
Fightn_Tiger
This is the one I'm running. it smooth(no sticking) and has a good range of motion. ordered it from Fausto at Motoxcycle
http://www.motoxcycle.com
Old Aug 10, 2010 | 03:51 AM
Coxbow's Avatar
Coxbow
Sorry if I wasn’t clear, I mean the same one the recent Touring models have, the throttle sends a signal, cableless…
The shape of my ape makes it impossible to use an internal throttle
Old Aug 10, 2010 | 04:28 AM
QS78's Avatar
QS78
i dont think ur handle bar is worst than RSD vintage. I'm working on it now. will see if it is possible !!
Old Aug 10, 2010 | 05:18 AM
Coxbow's Avatar
Coxbow
It’s a crappy pic but here it is
Old Aug 10, 2010 | 08:37 AM
QS78's Avatar
QS78
almost the same. will let u know how it goes.
but I can see that u are already using an internal throttle kit but with external cable ?? or is it only the picture !!
Old Aug 10, 2010 | 09:35 AM
Nautilus's Avatar
Nautilus
ok, so what ur looking for is an electronic throttle... that way there is no "cable movement" as in the traditional throttles... but it still needs an electric cable to go through the bars so it can transfer the signal :P
what u would be looking for is a conversion from the regular throttle to the electronic throttle... but I believe this cannot be done on carbed bikes, only on efi and I believe it will require a reprogramming of the ecu to accomodate the signal of the electric throttle and control the injection of gas...
I did a little search and couldn't find any conversions... just conversions from carb to efi but don't know if they are "fly by wire" friendly...
Godd luck with it
Old Aug 10, 2010 | 03:09 PM
Coxbow's Avatar
Coxbow
funny what you say there !
how can it be an internal throttle if the cable is outside ?!
