break light
Old Aug 11, 2010 | 05:27 PM
fatboy1340's Avatar
fatboy1340
6th Gear
Default break light
i have a 94 fatboy. when i apply the front break the breaklight comes on but will not go off unless i jiggle it around. any suggestions?
Old Aug 11, 2010 | 07:50 PM
Rockyriver's Avatar
Rockyriver
Either the switch in the housing is sticking or the lever needs a little lubricant. I would try some WD-40 or an equivalent on the lever at where the pin goes thru and on the switch itself in the housing. Just take the two bolts out and open up the housing. You will need to take the bolts off that hold the front master cylinder off also. Be sure to put a towel over your gas tank and fender so as not to scratch your paint if you drop something.
Old Aug 11, 2010 | 11:11 PM
ROMPUS's Avatar
ROMPUS
That should take care of it.
Old Aug 12, 2010 | 01:21 PM
fatboy1340's Avatar
fatboy1340
6th Gear
thanks bro.
Mpderksen
May 17, 2015 07:22 PM
WP50
EVO
13
Jul 22, 2012 08:04 AM
indiablue
Mar 17, 2012 04:36 PM
Kramer
Wheels/Tires
May 22, 2010 12:09 PM
