Axle Nut sizes
Old Aug 17, 2010 | 03:27 PM
Malingerer's Avatar
Malingerer
Default Axle Nut sizes
Does any one know the size of the socket I need to remove the front and rear axle nuts so I can remove my wheels on a 2010 Deluxe.I have from 1" -1 9/16" Nothing seems to fit correctly.Sorry for the dumb a$$ questions. Thanks Tom
Old Aug 17, 2010 | 06:32 PM
Rakthi's Avatar
Rakthi
The rear is a 36 mm metric. For the front you have to wait a bit. Wrote it down somewhere, will see if I can find it.
OK, found it,
to get the rear axle out on my xbones I used a 36 mm socket on the left and a 1 1/8 inch wrench on the right to stop the axle rotating
to get the front axle out, I used a 24 mm socket on the left and a 15/16 inch wrench on the right to stop the axle rotating.
Hope this helps and your 2010 Deluxe uses same nuts as my 2009 Xbones
Old Aug 17, 2010 | 07:20 PM
Malingerer's Avatar
Malingerer
OK, found it,
Much Thanks I was going nuts trying to figure it out. Metric????? That explains it
steelpix
Oct 13, 2014 03:52 PM
glyn fxdwg
Jul 1, 2011 12:01 AM
PearlWhiteGT
May 18, 2011 04:07 PM
raptoid780
Sep 21, 2010 11:43 PM
wadejesu
Feb 22, 2007 07:04 AM
