Rear Axle Nut
Old May 17, 2011 | 08:15 PM
PearlWhiteGT's Avatar
PearlWhiteGT
Default Rear Axle Nut
Trying to determine the correct size of the rear axle nut on a 2008 Train. Does it take a 36mm socket & a 1 1/8 wrench on the other end? If I take the axle nut off will it change the position of my tire? If I don't mess with the axle adjuster then it should stay aligned & not mess with the slack of the belt correct?
Thanks!
Old May 18, 2011 | 06:14 AM
Malingerer's Avatar
Malingerer
That is the same size my Deluxe was so it sounds right.
Old May 18, 2011 | 12:43 PM
PearlWhiteGT
Removing the axle nut won't change the angle of my tire though right???
Old May 18, 2011 | 01:01 PM
DR. V-TWIN's Avatar
DR. V-TWIN
Former Sponsor
It will stay where it is as long as you do not move the axle adjusters. 36mm
Drew
Old May 18, 2011 | 04:07 PM
PearlWhiteGT
Thanks Drew, I'm going to order that RSD air cleaner in a couple of weeks!
DarkManC
Mar 5, 2014 08:31 PM
Fabdad73
Sep 27, 2008 10:06 PM
madcitycustom
Jun 15, 2007 02:55 AM
wadejesu
Feb 22, 2007 07:04 AM
