Heritage fog lights not working
Old Aug 23, 2010 | 05:44 PM
Late Bloomer's Avatar
Late Bloomer
Default Heritage fog lights not working
My new to me 05 Heritage is as close to perfect as I could ever expect but the fog lights do not work. Previous owner says he knows nothing and I have checked the fuses and tried the switch a bunch of times. Need to check bulbs but seems unlikely that both went out at the same time. What else should I check??
Old Aug 23, 2010 | 07:54 PM
jimmers1817's Avatar
jimmers1817
Some new owners don't realize they only work when the low beams on on. Only thing I could think of. Or maybe the switch is bad. Probably where I'd check next. Find out if you have 12v getting to the switch.
Old Aug 23, 2010 | 09:51 PM
oct1949's Avatar
oct1949
Yeppers, they only work on low beam,,, unless they've been wired around,,,
Diff check out the bulbs them work backwards.
Old Aug 23, 2010 | 10:41 PM
Other Sheep's Avatar
Other Sheep
My brother in law had both of his burn out at the same time. Kind of strange when you think about it unless one was bad and the other finally went. Or maybe a voltage spike but you'd think that would burn out more than two bulds. Different.
Katzz
Aug 18, 2017 08:56 AM
Prot
EVO
47
Sep 18, 2016 08:17 AM
bluelineman
Jul 23, 2012 11:17 PM
tarcedo
Sep 5, 2007 10:55 PM
sincityharley
May 23, 2007 03:14 AM
