Help with rear shock
Old Sep 7, 2006 | 12:29 AM
Hogaholic's Avatar
Hogaholic
Default Help with rear shock
I need to adjust my rear shock, and cant figure out which is the jam nut you have to loosen. Is it the one at the shock or at the end of the shaft at the mount?
Old Sep 7, 2006 | 12:35 AM
Shovelhead Bob's Avatar
Shovelhead Bob
Default RE: Help with rear shock
The nut closest to the adjuster plate......
Once you get it loose, you need to use a pin spanner to rotate the plate (Both shocks) an equal number of turns in (Raise/Firmer) or out (Lower/Softer)....
Once you have done both shocks, then you tighten the nuts back to the plates.....
Have fun, it's a bear the 1st time......
Old Sep 7, 2006 | 12:37 AM
hdsd05's Avatar
hdsd05
I have to asume all softails are the same. The jam nut is located right in front of the shock. For less than $10 you can buy the spanner wrench from a dealer. Just make sure that you adjust them equally. I used some chaulk to mark them than turned one side at a time. (turned and tightened jam nut, than did the other side) I would advise you to purchase a service manual also. Best money I ever spent.
Old Sep 7, 2006 | 12:49 AM
Hogaholic's Avatar
Hogaholic
So you dont do anything with the acorn nut at the mount.
Old Sep 7, 2006 | 12:53 AM
hdsd05's Avatar
hdsd05
Not unless you want a big problem. Don't touch it! I don't want read about you crashing. Makes a big mess plus theres the insurance claims, paperwork, hospital bills, etc.
Old Sep 7, 2006 | 12:56 AM
Hogaholic's Avatar
Hogaholic
Thanks !!!
ORIGINAL: hdsd05
Dannyrider
Oct 27, 2021 02:03 AM
m1369x
Jan 17, 2020 10:42 AM
nutmegger1957
Sep 10, 2015 12:54 PM
Prw3
Jan 8, 2014 12:23 PM
abjones
Sep 30, 2006 05:39 PM
