Thanks for the reply Kowan! Anyone have a good link for the info on how to notch out the struts to fit over the mounting tab on each side of the Danny gray seat for FXCW 2up option? Tried searchin the forums but couldn't find the info.
i need plastic thangy though my scoot is slammed
hey kowan since you ain't using your colorform clear plastic thanng how bout hookin a
bro up?
I would, (you are from Illinois afterall) but if I decided to go with a lowering kit I'd need it myself.
One of my riding buddys is from Chicago. I was teasing him and asked what he was doing in Chicago and he told me he was born and raised there. I'm from Decatur Ill.
Funny how many are either still in Ill or originally from Ill you meet.
bro up?
Hey Mike!
Quick question for ya..I was planning on getting the FXCW seat, but I still want to use the trick seat. I don't need to store it under the seat, but i still want the option of flipping the seat out. How is your seat bolted to the bike? I guess I should have looked at it when we went riding!!
I listened to Mike, and got a FXCW (Rocker) seat, had to get the mount shield for the Rocker seat as the back studs are narrower than the C. Much more comfy, rode almost 300 miles last weekend, and my hands were tired but not my rear. The FXCWC seat gives up confort to get the passenger seat.
Pat in Tennessee
2008 Rocker C- FXCWC SE Stage II 103 Cu. In. Big Bore Kit (1690 cc) 3-7/8” SE Pro 4-3/8” Stroker Flywheel and Rod Assy. SE Pro (MVA) Heads SE Pro 58mm EFI Throttle Body SE 255 Cam (Torque) SE Roller Rocker Arms SE Roller Tappets SE Valve Spring Kit SE ST Spark PLugs SE Pro Tuner Kit Vance and Hines Big Radius Exhaust SE Stage 1 Air Cleaner Kit SE Hi Flow Billet Air Cleaner FXCW Luggage Rack Kit (Now Chrome Plated) FXCW Seat
nada i have ditched the 2nd seat
some one has modded a c seat i believe though
the seat is just pressed in by those 2 rubber gromets
