wheel spacer
Old Sep 22, 2010 | 09:14 PM
06fxsti's Avatar
06fxsti
Default wheel spacer
well installed superbrace yesterday looks great and works but I noticed a slight problem. Has anyone hear installed a superbrace on a 2006 fxst. I purchased 5193 and my problem is when everything is torque i have a gap between the right fork leg and the spacer about 1/4". The spacer is tight and the wheel is center and rides good, the spacer is tight because on the right side the axel pin has a collar for the spacer to butt up against. If i attempt to make the spacer tight agaist the right fork leag and torque everything then the forks bind when pushing on them. I also tried replacing the right side spacer with one of same thickness as the left,now have two left side spacers wheel still centered still a gap not as big no problems riding. Is this going to cause a problem? I have contacted superbrace waiting on a reply. thanks for any input on this matter.
ShiftyCapone
May 12, 2017 12:00 PM
T_Dogg80
Jun 16, 2013 02:30 AM
goats
Aug 7, 2012 06:25 PM
big_e78
Mar 8, 2010 10:51 AM
03RKC
Apr 5, 2007 09:01 PM
