How do I lower the rear end?
Old Oct 6, 2010 | 11:18 AM
JayOhh's Avatar
JayOhh
You're right. Not going half *** on the suspension. Well season's as good as over here, so I got about 6 months to figure it out. Who knows, maybe those $1500 for the shotguns will turn up.
Regarding the height, they will for sure be the easiest to work with. But is it as easy as it seems to get the suspension working right at the different heights? For a suspension to work right you need to have the stiffness, height, rebound and sag correct. The Shotgun-shocks seems to be a little too easy to be true hehe...
Old Oct 6, 2010 | 11:24 AM
Ash16's Avatar
Ash16
I have Progressive 422's lowered 2" and ride two up every once in a while. Pretty rough ride. I'm at 175 and my wife's at 115. Probly should adjust it when she's on but I don't.
Old Oct 6, 2010 | 11:31 AM
story808's Avatar
story808
I go 2up sometimes... and I'm down more than 2 inches... I'm running progressive 413's... If the wife wants to ride then she gotta deal with it I ain't crawling under the bike to adjust the shocks.
If you're only going down 2 inches you'll be okay with progressives.
Old Oct 6, 2010 | 11:53 AM
SMF's Avatar
SMF
Yea bro I got
the hi lo air ride it was the best availible when I had money but I think they go
for
like 600 now I have no complaints
Old Oct 6, 2010 | 12:11 PM
SuspendedUser's Avatar
SuspendedUser
how low can the hi lo air ride and the shotguns go? more than 2''?
Old Dec 27, 2010 | 04:57 PM
ramhunter9's Avatar
ramhunter9
I would like to know also ?
Old Dec 27, 2010 | 05:11 PM
JIMSFBL's Avatar
JIMSFBL
Dropped mine almost 4" below stock and i can raise it to 1" above stock (approx 5" of range). And yes it only takes 30 seconds to set it at any hieght while adjusting the firmness of the ride with the 2nd toggle switch. Best Mod yet!
my stock seat hieght was 24 1/4" and when I slam it down it is 20 3/4"
magnum629c
Jan 28, 2013 04:20 PM
JHL-ShinySideUp
Jul 20, 2012 07:13 PM
smoen81
Oct 22, 2011 11:41 PM
hellfrozeover
May 21, 2011 07:10 AM
Ragin_Republican
Apr 19, 2005 03:57 AM
