how to changing shocks
Old Jan 27, 2013 | 05:34 PM
magnum629c's Avatar
magnum629c
Default how to changing shocks
I would like to.add 422 shocks whats involved? can I just change one shock at a time and not put bike on a lift?
Old Jan 27, 2013 | 05:37 PM
Juan L's Avatar
Juan L
Moderator
If they are the same length just one at a time. If longer or shorter you'll have to put the bike on a lift so you can manipulate the wheel height.
Old Jan 27, 2013 | 05:40 PM
Sgt_Jim's Avatar
Sgt_Jim
It's easier if you put the bike on a lift and use some blocks under the rear tire to take the tension off.. it's just 1 bolt and a few locknuts/washers per shock.. takes hardly any time at all.
Old Jan 27, 2013 | 05:53 PM
jreichart's Avatar
jreichart
I would venture to say a jack is required. First, the rear shock bolts are superman tight and I don't think you'd have enough room to get a good swing at them with the bike on the ground. Also there is the tension issue. Totally worth the $100 investment in a basic jack and some 4x4 blocks. IMHO.
Old Jan 27, 2013 | 05:59 PM
QC's Avatar
QC
My guess is the 422s are longer than stock, hence their height adjustability. So you're probably gonna need a lift. Even easier with a both a floor jack and bike lift, too.
Old Jan 27, 2013 | 06:13 PM
rnl_1200C's Avatar
rnl_1200C
agreed - this is exactly what I did and it was easy
Old Jan 27, 2013 | 06:28 PM
cosshog's Avatar
cosshog
Used bike lift for the bike (make sure it is all the way forward on the frame so you can get to the bolts) then I used a car jack under the rear tire to adjust the height of the wheel. Just be patient and take your time, the instructions are pretty good plus you can call their tech support for help if need for adjust ability.
Old Jan 27, 2013 | 06:46 PM
magnum629c's Avatar
magnum629c
thanks.guys
Old Jan 27, 2013 | 06:59 PM
silent bob's Avatar
silent bob
Much easier with a lift and like cosshog said, you will need to be able to lift the back wheel when your are aligning the rear shock bolts.
Old Jan 28, 2013 | 09:02 AM
magnum629c's Avatar
magnum629c
ok thanks
