backfire problems.
Old Sep 15, 2006 | 10:43 AM
skullandcircle's Avatar
skullandcircle
Default backfire problems.
last night I jumped on the bike for a short ride and it was backfiring like crazy. (from exhaust & carb). It also seemed to be popping air. It ran fine when I parked it last wednesday. It also seems to idle fine, just when I hit the throttle is when it starts backfiring. I looked in my hd owners manual to try and trouble shoot it but that didnt do much good. Just wondering if anyone can give me some pointers.
93 flstc
figures it would screw up when the weather is supposed to be nice here in indiana...[:@]
one other thing, does this year bike have points? I couldnt seem to find them anywhere in the manual.
Old Sep 15, 2006 | 11:29 AM
mimo's Avatar
mimo
Default RE: backfire problems.
Your mixture is not good. I had the same symptoms the day I tried to re-jet the bike by myself... Could no make a block with less than 10 detonations...
I'm no pro towards carburation.
Good luck.
Old Sep 15, 2006 | 11:46 AM
skullandcircle
ORIGINAL: mimo
Good luck.
thing is, I havent changed or adjusted anything.. hopefully it is something simple but that usually isnt they way things work out.
Old Sep 15, 2006 | 02:33 PM
softail2005's Avatar
softail2005
Suggest you pull the plugs and take a look at the color. They will tell you a lot. Black and sooty, too much fuel. Should be nice brown color. Plug could be fouled out. Could be some bad gas. Other than that I would see the dealer. Bad sensors can do a lot of mean things.
Old Sep 16, 2006 | 12:17 AM
skullandcircle
ORIGINAL: softail2005
they were black and sooty.. I am going to get new plugs and change the gas.. hopefully that is it..
thanks again everyone for the posts...
Old Sep 16, 2006 | 01:04 AM
wa state rider's Avatar
wa state rider
You didn't grab the diesel handle did you?
Old Sep 16, 2006 | 01:08 AM
skullandcircle
ORIGINAL: wa state rider
nope.. [8D]
Old Sep 16, 2006 | 01:23 AM
Tucker99's Avatar
Tucker99
Let us know what the problem is. We may need the solution one day...
Old Sep 16, 2006 | 01:25 AM
skullandcircle
ORIGINAL: Tucker99
sure will.. if my luck has anything to do with it, it will be a new engine. [:@]
ended up being a burnt spark plug.. woot, easy fix
digthemlows
May 12, 2016 04:29 PM
kd4tsc
Exhaust System Topics
11
Jan 20, 2010 06:17 PM
jagular1785
Jun 7, 2008 01:58 AM
EyernHeadHD
Ironhead
Jun 3, 2008 08:48 PM
Crazy B
Mar 4, 2007 08:55 PM
