Heritage help
Old Oct 8, 2010 | 09:42 PM
chop09's Avatar
chop09
Default Heritage help
Pretty simple question and if i owned a Heritage I'd know ... I want install bareback quick release hardware to a 04 heritage that already has quick release backrest set up.
Is there anything I need to know....about installing barebacks for the saddlebags...
Is the bareback hardware all i need.... do i need another bracket other than stock to get this done. Anyone with similar set up? thanks
Old Oct 9, 2010 | 05:56 AM
Phantomryder's Avatar
Phantomryder
I had the barebacks installed at an HD dealer with the detach kit from harley. You don't need anything else, I believe you need to use the longer bolts to mount both the barebacks and detach kit. Hope this helps...
Old Oct 9, 2010 | 11:12 AM
RetNYPD's Avatar
RetNYPD
Barebacks come in 2 styles. One style specifically for the quick disconnect sissybar and the other for the "non" quick disconnect sissy bar. Just get the ones for the quick disconnect and you'll be good to go.
Semper Fidelis!
T
Old Oct 9, 2010 | 02:16 PM
chop09's Avatar
chop09
Thanks for the help fellas
Pete3323
May 2, 2015 09:00 PM
Pete3323
Apr 17, 2015 08:36 PM
lionsqrne
May 2, 2011 11:35 AM
ski917
Jan 5, 2010 04:43 PM
Stevenml155
Jan 24, 2006 11:53 PM
