fuse help
Old Oct 15, 2010 | 10:26 AM
tdmiller1965's Avatar
tdmiller1965
Stage II
Default fuse help
I have a 2005 Deluxe, not getting power. Anyone know where the main fuse is located ? or what to check ? accessary works but not ignition
Old Oct 15, 2010 | 10:29 AM
hspring03's Avatar
hspring03
Take the console off..flip it over and check the connections... They can come loose
Old Oct 15, 2010 | 10:41 AM
tdmiller1965
Stage II
/when I turn on the ignition, everything goes off just loses all power
Old Oct 15, 2010 | 10:53 AM
bbeavers76's Avatar
bbeavers76
Fuse box is under the seat.
Old Oct 15, 2010 | 10:57 AM
hspring03's Avatar
hspring03
You can have a loose connection under the console. I would check there first.
Old Oct 16, 2010 | 06:43 AM
tk353's Avatar
tk353
bad on off switch, does acc side work? the main fuse on mine is 40amp in a wire off the battery. check the grounds. there is a power relay on mine.
speedglide
11
Aug 31, 2024 10:55 AM
LI98sporty
Aug 4, 2018 04:10 PM
blueangel73
Sep 20, 2017 03:50 PM
KSully63
Mar 13, 2014 09:18 AM
jack56
Dec 18, 2012 11:28 AM
