arming disarming alarm
Old Oct 26, 2010 | 09:04 AM
98glider's Avatar
98glider
Default arming disarming alarm
A friend of mine just purchased a 2002 Heritage Softail and no manual was given I was wondering is there a sequence for to arm and disarm He installed a new battary.in the key ring thanks Charly
Old Oct 26, 2010 | 09:07 AM
DR. V-TWIN's Avatar
DR. V-TWIN
Former Sponsor
Push the fob once to arm it. Push it twice quickly to disarm it.
Drew
Old Oct 26, 2010 | 01:58 PM
Nickrc3's Avatar
Nickrc3
+1 -
A red indicator within the speedo should flash each second upon arming. Also, the system should provide single and double chimes with the sequence DOC described.
Old Oct 26, 2010 | 03:40 PM
gforrest2's Avatar
gforrest2
On mine, it takes more than a quick push to arm. More like a push and hold for a second until the bike acknowledges with the turn signal flash and the red light in the speedo blinking. Disarming is like everyone else has said-two quick pushes.
Old Oct 27, 2010 | 06:32 PM
98glider's Avatar
98glider
thanks for the fast response We will try it
Old Oct 27, 2010 | 09:14 PM
snook592's Avatar
snook592
So did it work ??????
Old Mar 19, 2016 | 04:38 PM
Historygeek888's Avatar
Historygeek888
Stage IV
Default Signal Lights and Alarm system trouble
I recently purchased a 2002 Heritage Softail Classic, am having the same issue. The alarm system has never responded to my fob, I had basically resigned myself to not using the alarm system. The rear signal lights worked when I bought it, but about 4 weeks ago they stopped working and around the same time the red key indicator light in the speedometer came on. I know that the signal lights and the alarm system are related, but I want to know if there is any way to restore the use of the signal lights, or check to see if they will work, without replacing the entire security system module. I just sank $1000 into the bike for another issue, would rather not spend another $450 if I don't have to. Would welcome any assitance or advice.
Rabid
Oct 15, 2023 07:35 PM
jeff5105
May 28, 2010 06:33 AM
arachman
Aug 21, 2009 01:24 PM
edfromptowne
Oct 7, 2008 09:59 PM
Effex
May 24, 2006 09:11 PM
